Hot Ground Reverse after GFCI Test
So I am testing my GFCI circuit and noticed that when I do a test of the outlet (i.e. push button on the front), I got from a normal indication on my 3 LED tester to a Hot/Ground reversed indication. I recognize that a hot/ground reversal is usually a loose neutral somewhere but I checked the outlets and the electrical panel and everything looks fine. There is only the GFCI outlets and 2 load outlets down stream from the GFCI. Any ideas what might be causing my problem?
Are the line and load sides of the GFCI receptacle wired to the correct cables? After pressing the TEST button, there should be no power at all after the receptacle. A faulty GFCI receptactle could also be the problem here.
Everything was wired correctly I think.
So I verified that I wired it correctly (which made me feel a little less crazy). But I checked everything and it all looks fine. Could a bad gfci result in this tester reading as was mentioned?
So my theory, and this is a theory at best, is that the relay that opens the natural is opening on a test of the gfci, but the hot is not opening. I guess it's possible right? Maybe the hot welded close at some point? I don't know enough about the internals of a gfci outlet.
You said you verified that you had the hot supply line and it's associated neutral on the line side ?
Very easy to get backwards (line and load swapped) and that will cause strange readings.
A GFI receptacle should not show ANY voltage when tripped. If it does and it's wired correctly... it's defective and needs to be replaced.
