Faulty 3 way switch
Faulty 3 way switch
Just moved into a new town home (built 2004). The 3 way switch operating hall light upon entry from garage does not work properly (this was missed at inspection). The 1st switch (near entry door) does not turn on light in either position, regardless of position of 2nd switch (near front door). The 2nd switch does turn on lights in up position, regardless of position of 1st switch. If either switch is placed in 'middle' position, light does not work. In examining 1st switch box, there is a six wire cable...ground, 2 black (attached to two left hand terminals on switch), 1 red (attached to right hand terminal on switch), and 2 white (spliced together via wire nut). In examining 2nd switch, same situation as to which colored wires are attached to terminals. There are two other switches in this box. I didn't pull them out, and there is quite a bit of wiring in this box, so not quite sure of the details of what all is going in and out of this box. Hoping there's a simple solution (i.e., problem not 'in the walls'). Thanks.
(Note testing must be done with a multimeter, preferably analog, or a test light, or a solenoid tester. You can't use a non contact tester.)
Next up we will try to sort out the other switch box.
Welcome to the forums.
Just to add to Ray's reply but don't want to muddy the water. If you have a two wire and a three wire cable at each ends....... the black wire from the two conductor cable needs to be on the common terminal at both switches.
Just FYI... there is no side or top or bottom to the screw terminals on a three way switch.
There are three screw terminals. Two are the travelers and are always the same color. Those two terminals are interchangeable. The third screw is always darker and is the common terminal. This is the important one.
OK, I found my circuit tester. It's a cheap Radio Shack digital, but seems to work OK (I have tested it on model train stuff). I also put the contact leads into a live outlet, and got a 120 volt reading. As you said on your first reply, there is a 2-conductor cable and a 3-conductor cable. I cut the power, and carefully sorted out the white and black wires from the 2-conductor cable, and freed from any connections. I turned the power back on, got a 0 reading from my tester. This was true regardless of the setting of the other wall switch (near front door, which does work to turn light off and on). Hope this helps. Thanks.
Yes, the black wire from the 2-conductor is connected to the common terminal (for switch near garage). Figuring out what is going on with the other switch is challenging, but here goes. There are three switches in the box...the 3 way in question, a 2 way for laundry fan, and 3 way for foyer light (other 2 switches work fine). There are six cables coming into the box....three 3-conductor and three 2-conductor. For one of the 3-conductors, the black wire goes to common terminal on the bad switch and the red wire goes to one of the other terminals on bad switch. The third terminal on this switch has a black wire, and comes from a splice....black wire to fan switch, black wire from a two conductor cable, and black wire from a three conductor cable (this three conductor seems to be 'extra'....not directly connected to either of the 3 way switches...). Five of the white wires are spliced together. The other white wire seems to be painted black after it comes out of the conductor a ways, and is connected to the foyer light 3 way switch. I realize I am not fully explaining the exact connections of all 15 wires coming into this box, but maybe there's enough info here to diagnose. If not, I can fully pull everything out and go deeper...just not sure if needed. Thanks.
