Can you identify this plug?
Old 09-19-16, 11:11 AM
K
I did a google search but couldn't find out what this is called. I need a male
Old 09-19-16, 11:28 AM
T
Received 3 Upvotes on 3 Posts
Looks like a PC cord that plugs into a monitor or PC. Google PC Cord Extension. I think they may be called C13
Old 09-19-16, 11:36 AM
I
Received 45 Upvotes on 43 Posts
The cord is an IEC C13 and the corresponding inlet is an IEC C14.
Old 09-19-16, 08:12 PM
Received 125 Upvotes on 110 Posts
Main question is why do you need a male plug?
That type cord was intended for one thing, to be plugged into the back of a computer.
Old 09-19-16, 08:26 PM
ray2047's Avatar
Would this help you? https://www.amazon.com/Accu-Cable-Fe...KBB4YCVCJ279K4 Or if you need a panel mount just pull one from a junk computer power supply.
Old 09-20-16, 01:49 PM
K
Thanks Guys. The plug goes to a lighting reflector. I'm putting together a new Metal Halide Ballast box and wanted to use the same reflector without modification.
I just checked the back of an old power supply, yup that's it. All legal stuff under those lights, have a great day
Old 09-20-16, 01:56 PM
K
Actually that's perfect and cheap, thanks
That was meant as a reply for post #5
