Adding dedicated circuit for landscape transformer
Old 10-07-16, 01:02 PM
B
I am adding a dedicated circuit to my service panel for my 12V landscape lighting transformer.
Instead of using GFCI outlet outside, could I use GFCI breaker on the panel. Is there any benefit to using the GFCI / CAFI combo breakers??
Thanks
Jan.
Old 10-07-16, 02:21 PM
Received 1,118 Votes on 1,038 Posts
GFI breakers are more expensive than a GFI receptacle but in my opinion hold up better and last longer out of the weather.
You could use a combo breaker but only GFI is required for outside use.
Old 10-08-16, 01:32 PM
CasualJoe's Avatar
Received 87 Votes on 77 Posts
GFCI and AFCI are two different things, but both types of protection are provided by "Dual Function" circuit breakers. I doubt you need the AFCI protection.
