Fishing through flexible metal conduit
Old 10-11-16, 02:09 PM
A
I am trying to fish through a 50' section of 1 1/2" flexible metal conduit without success so far. I tried a vacuum on one side and was going to feed a string on the other but there was no suction with my shop vac -- the FMC leaks too much air. My metal fish tape can't get past the curves. I tried pushing a coax cable through but it bound up too. Any ideas? Has anyone used a 3/16" or 1/4" steel cable as a fish?
Old 10-11-16, 02:13 PM
I
Received 45 Upvotes on 43 Posts
Maybe a fiber fish tape? You could try to blow or vacuum a conduit mouse (tie string to a plastic grocery bag) to help with the air pressure problem. Sorry I don't have much more, FMC is tough to work with in any significant distance. You may have to breach the wall and install a pull box at the midpoint.
Old 10-11-16, 02:36 PM
Received 3,741 Upvotes on 3,356 Posts
Did I read correctly.... 1-1/2" FMC ?
That's pretty large. I use a metal snake with a small hard plastic ball on the end.
A kid's toy ball..... I drilled it out and stuck it over the snake's hook.
You must use something with a round end. Anything flat..... coax, steel cable, snake, etc. will only get caught in the ridges at the curves. A fiber fish tape with a whisk on the end would also work.
Old 10-11-16, 02:44 PM
A
Yes - 1 1/2" aluminum flex. I ran it in the ceiling when it was open for a remodel a few years ago thinking it'd be plenty large to fish through. I should have ran a fish line through it when I could have stretched it straight on the ground.
Old 10-11-16, 02:48 PM
Now when you get thru it..... leave a fish line for future use.
Old 10-12-16, 04:42 AM
Tolyn Ironhand's Avatar
Received 809 Upvotes on 682 Posts
You didn't say home many bends you have but a steel fish tape with a leader helps. Klein Tools Fish Tape Leader-50350 - The Home Depot
It might also help to try from the other direction.
