Best method to add additional outlets to walls
Old 10-19-16, 08:47 AM
C
My basement have a couple of walls that have no outlets. I like to add at least two or three outlets per wall. Do I just extend it from an existing outlets or do I have to run the cable from the breaker? What are the limits if any? Disadvantages and advantages of running it from an existing vs. from the breaker? But most of all, I want it to be legal.
Thank you.
Old 10-19-16, 08:54 AM
Received 94 Votes on 83 Posts
First question is whether your current receptacles are grounded. If not, you cannot extend the circuit and would have to run a new one.
Old 10-19-16, 09:05 AM
C
Okay, so if it's grounded then I can extend as many outlets as I can, correct?
Old 10-19-16, 09:23 AM
Within reason - best is to estimate what loads you might have plugged in to determine whether you should run additional circuits.
Old 10-19-16, 12:32 PM
pcboss's Avatar
Received 92 Votes on 79 Posts
The planned usage and existing load would determine if a new circuit was needed or just extend the current circuit.
Old 10-19-16, 01:32 PM
C
The additional outlets are just for convenience. It's not for running additional loads.
Old 10-19-16, 01:52 PM
F
Received 36 Votes on 28 Posts
Surface run PVC conduit and boxes using individual conductors will be the easiest wiring method.
Old 10-19-16, 05:01 PM
Tolyn Ironhand's Avatar
Received 223 Votes on 196 Posts
Are your walls finished or open? Are there studs or just bare concrete/block wall?
Old 10-20-16, 07:10 AM
C
The walls are not finished yet. However, half of he walls already have sheetrock on it but the bottom does not have anything yet. It has 2x4 studs.
Old 10-20-16, 10:02 AM
pcboss's Avatar
Drill the studs at least 1 1/4" back from the face and run the cables in the holes.
Old 10-20-16, 06:00 PM
I agree. Drilling through the studs with a 3/4" bit and pulling NM-b cable (Romex) would be the fastest and easiest. For conveiance, just tie onto an existing circuit matching the wire size of that circuit. If you think you will want to put some larger load on it, then run a new circuit.
I highly recommend these spade bits for drilling holes: Bosch DareDevil 1/2 in., 3/4 in. and 1 in. Spade Bit Set (3-Piece)-DSB5003 - The Home Depot They work very well as long as you do not hit any nails.
I also suggest using plastic nail up boxes.
Old 10-21-16, 10:02 AM
C
Thank you for all the help.
