Light switch trouble
Old 10-22-16, 04:10 PM
C
Hi.. needing some help here, please..
I have 4 switches in my bathroom. In order from left to right in the picture..
(1) Fan
(2) Overheat heat lamp
(3) Sink/main light
(4) Shower light
The switch for (3) broke and I changed it out. Seemed simple enough. Previously all 4 switches worked independently. I could have any light on by itself. Now, light (3) MUST be ON for any of the others to work. I was fairly certain I wired the switch exactly as it was. Did I maybe use the wrong type switch? I have no idea if it was a single pole or other. I just chose one not realizing there was a difference. How can I tell the difference by looking at the switch? I actually did this months ago and threw out the old switch.
Thank you!
Old 10-22-16, 06:26 PM
P
Received 682 Votes on 629 Posts
It sounds like you got something loose when installing the new switch. Was there a wire nut inside the box that had multiple black wires? If so I'd check to make sure all those wires and the nut are tight and secure. Likely there is one wire carrying the current/hot that is loose or not connected and when you fix that everything will work again.
Old 10-22-16, 06:51 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Not a loose wire. I'd be willing to bet you had a back stabbed wire on the old switch and you didn't pare it with the same wire that was on the screw of that terminal. One of those wires was the hot in and the other hot out.
Please open the switch box with the new switch, pull the switches out and make pictures of the wires and and their connections. http://www.doityourself.com/forum/li...rt-images.html
Old 10-24-16, 07:11 PM
C
Size:  32.3 KBName:  3d.jpg
Size:  25.7 KBName:  3e.jpg
The switch on the left is the one in question. Thank you.
Old 10-24-16, 07:19 PM
ray2047's Avatar
The looped black is probable the hot in. Probably the wires you back stabbed are reversed. Back stabs are unreliable. Use pigtails instead. I'll be back later with more instructions.
Old 10-30-16, 07:22 PM
C
Apparently the wires were reversed like you said. I swapped them and it works properly now! Thank you for all the help.
Old 10-30-16, 08:37 PM
ray2047's Avatar
Glad you got it. Thanks for letting us know.
