Replace Old ITE Imperial
Old 12-04-16, 07:28 PM
A
Going to replace my old breaker panel(1972) with a Homeline SQ-D 125a equivalent. I'll keep it simple.
Because previous owners put incorrect breakers in there, tandems where tandems don't belong. There is some charring on some of the bus bar connectors. I removed those breakers and have empty space now.
Service(main) panel has 125a disconnect that connects to panel I am replacing via about 130' of 2/0 2/0 2/0(bare) al SER. Technically means it is a sub panel.
Question is can I just swap it out and keep the existing 3 wire system and let the neutrals and grounds share bonded bars and not isolate them (and leave out the green bonding screw) because this was the original design. I know it not is good as a 4 wire, but is it legal and safe( I know the new panel with be safer by defacto). If i need to add the 4th wire can it be a solo, or do I need to replace the whole thing with a 2/0-3 + ground? I have put in plenty of new sub's and always used 4 wire, but first time replacing an older panel.
Old 12-06-16, 05:11 PM
CasualJoe's Avatar
Received 178 Upvotes on 161 Posts
Yes, that is a subpanel and the SER feeder is a 4-wire feeder. SER cable has 3 insulated conductors and 1 bare grounding conductor.
Your question makes no sense. What 3-wire system, you have a 4-wire SER cable feeder. The panel you are changing is in the same building as the 125 amp disconnect.....right?
Old 12-06-16, 06:19 PM
pcboss's Avatar
Received 175 Upvotes on 153 Posts
Can you post a picture of the panels in question ?
Old 12-14-16, 06:22 AM
A
I guess that was misleading. The Bare wire is the same size as the 2 mains, not smaller as the in the some bare(grounds), but there is only 3 wires. Here is the pic. And correction it is a 100amp breaker in the main and I am not going to swap that. Here is a pic.
Old 12-14-16, 01:29 PM
I
Received 45 Upvotes on 43 Posts
This is up to the local inspector. Sometimes on what is strictly a panel swap (no increase in amps) and no change of the other service components, they will not make you replace the 3 wire feeder as it would be grandfathered as part of the original installation.
If you do need to install a new feeder, you would need to replace the entire cable with a four-conductor cable.
Old 12-15-16, 01:55 PM
CasualJoe's Avatar
There is the problem, that isn't SER cable, but SEU cable.
