I am so galactically stupid...
I don't know how I missed it.
I had to add a receptacle in a room with wood paneling. So I carefully removed the mouldings, the decorative trims, the quarter rounds etc...then I ran the conduit to the desired location and mount the box.
Then I transferred the measurements to the wood panel to make the cut for the electrical hole. Perfect cut.
Then I mounted the wood panel, glued and nailed all the mouldings and trims and everything.
Then I realized I used the wrong mud ring. It should have been a 1/4" raised ring but I used a 1" raised ring. I don't know why I did that. Now I see the mud ring instead of being flushed with the finished panel, it is proud of the finished panel by 3/4"!!!
I don't even know what I was thinking. Now it's all nailed and glued.
Any suggestions besides ripping everything out AGAIN? Any "spacer" that can be used behind the plate?
I am so mad at myself!
How about picture framing around the ring with nice matching trim thick enough to be flush. It will look like a "feature".
Otherwise, you could cut the ring off flush and use 6-32 standoff spacers into drilled and tapped holes in the back of the box. Not sure the inspector would be happy, but as long the ring is flush with the paneling it should be OK.
They are called hex female male spacers or standoffs....
I agree! Several times over the years I've had to make a decorative wood spacer for the electrical device to work. If you stain/poly [before installation] it to match the paneling it will blend nicely and NOT look like a mistake
