Can I use lampcord?
Old 12-21-16, 04:18 PM
K
Question Can I use lampcord?
I have this thing:
https://www.amazon.com/Glentronics-I.../dp/B000JOK11K
The instructions say you can splice wire up to 100 ft.
Anyway, I want splice wire to go from my unfinished basement into the first floor.
Being an unfinished basement, do I still have to use CL2, CM, CMR or CMP wire just to penetrate the floor up into the first floor?
Old 12-21-16, 04:23 PM
P
Received 265 Upvotes on 223 Posts
Being battery powered you can use any low volt wire. I assume the wire is 22 or 24 AWG.
Old 12-21-16, 04:58 PM
E
Received 3 Upvotes on 3 Posts
Yes you can
The message you have entered is too short. Please lengthen your message to at least 25 characters.
Old 12-21-16, 05:48 PM
ray2047's Avatar
Lamp cord is not class 2 and therefore should not be run in walls. Best would be thermostat cable. It is class 2 and can be run in walls. Example: Southwire 100 ft. 18/2 Brown Solid CU Thermostat Wire-64162141 - The Home Depot
