Onan GenSet: 16V to Batteries
I have a 7.5KW Onan liquid-cooled diesel generator in my service truck. When it's running, there's anything from 14-16V coming off my truck's batteries. The less load the higher the voltage. Is this going to damage anything? If so I'm probably just going to disconnect the alternator. I don't want to ruin 4 6 month old batteries.
It would be borderline. Why do you have it connected to the truck in the first place? If it is for starting, I would isolate a battery just for that purpose and not have it conjoined to the truck.
While vehicle batteries are commonly called 12 volt, the system and charging voltages are higher.
Thanks for your replies, sorry I'm taking so long to respond.
I have it connected to the truck so I wouldn't have to buy 2 more batteries, and lose more compartment space. It was really easy to run another 2/0 from the battery isolator switch to the generator.
But 16V? Ive never seen a battery charger get above 14.5-15V.
If it's only a single heavy wire or a single heavy wire and one smaller wire it could be an internally regulated alternator.
Do you have a model number for that unit ?
There is currently a video on you tube of that genny from another fire department.
Shows a regulator for 12vdc. part # 185-2252.
Some good manuals....
onan 7.5 dkdfj parts manual_pdf
Attachment 75203
Attachment 75203
