Unused electrical boxes
The garage of house I just moved into has a number of electrical boxes with standard hot/neutral/ground wires, and solid cover plates over them. Is there any reason not to install receptacles so I can use them? Why might these have been installed with solid cover plates?
Thanks,
Matt
Thanks,
Matt
It looks like the box was used as a junction box only, no idea why someone wouldn't install a receptacle.
The garage requires GFCI receptacles.
Maybe the previous person didn't know what to do with 3 wires, which is to connect them as pictured with a single pigtail to the receptacle terminals.
Ok, thanks for the note about gfci. I didn't realize that since the other garage outlets aren't.
On your second note, two wires use the receptacle as a pass-thru, where 3 wires keep 2 twisted for the pass-thru and the third goes to the receptacle, correct?
Thanks,
Matt
Thanks,
Matt
Not correct.
If there are only two cables in a box (2 hot/2 neutral wires), you can use the receptacle terminals to continue power downstream.
If there are three or more cables, You connect ALL the neutral wires with a wire nut with a single pigtail to the receptacle. Same for hot, only one terminal will be used.
A safety note: If you run into any 3-conductor cable; a black, red, white and ground. Post back.
You may or may not have this cable in the garage, but precautions must be taken if you do.
In addition, you only need a GFCI on the first receptacle, wiring the downline receptacles on the LOAD side of the GFCI. That will protect all the receptacles.
