Which load center do you prefer?
This is a question to professional electricians in this forum.
Which load center do you prefer and which load center do you hate? Why and why not?
I know this has been discussed multiple times everywhere, but I'm just curious what electrician here prefer.
Personally, I don't really have a preference. I'd use any load center I can get my hands on with reasonable price. I like Eaton/Cutler Hammer Type BR because they are cheap and breakers are readly avilable. I also like GE's Q-Line slim breaker because it saves space (although you are achive same with tandem breaker in Type BR).
I don't really see advantage of Siemens or Square D Homeline. Squre D QO is nice with trip indicator, but then I can tell which breaker has tripped by looking at the handle anyway.
Pretty much all of current type of breakers and load centers has been outthere for a long time and proven to be safe. Aren't they?
I have never thought about it, but Cutler Hammer BR is a good panel. In reality all of them, including the Homeline's are good. Most breakers are inexpensive until you go to install AFCI's. That is usually the telltale mark. Not all breaker handles show tripped, and the little red indicator can help when there is no legend on the door to pinpoint a trip without turning them all off and on again.
Maybe some of the others have preferences with a better reasoning.
Not a pro electrician but have installed quite a few panels.
I like the siemens PL series...copper buss, neutral bars right in front of the breakers so they wire up cleaner and neater, all the neutral and ground screws come backed out so you don't waste time unscrewing them for every connection, two ground bars standard, invertable for bottom feed entry...
Also like the SQuare D plug on neutral panels, really handy with all the AFCIs needed now. But premium price.
I once had Brant breaker tripped, but stuck in on position. They are designed to trip to center, so must been defect or just being old. Slight touch with my finger moved handle to the center.
While trip indicator is a nice addition, not sure if it is worth paying more for.
I like the Cutler-Hammer CH and Square-D QO because of having a copper bus.
I like, and mostly use Siemens because they have been the best quality for a low price, but they are changing. Last Siemens load center I have bought only had a neutral bus on one side! I thought that was the dumbest thing to do to cheapen up a panel!
My latest panel that tops my list is Square D Homeline with the plug on neutral bus. When using a GFCI or AFCI breakers that are required in all locations starting 2017 NEC cycle you buy the plug on breakers at not only connect to the hot bus but also the neutral bus. There is no pigtail that you have to connect to the neutral bus from the breaker. Just connect the hot and neutral wires to the breaker, plug it in and you are done! Breakers and panel do not cost any extra then the pigtail breakers. I believe these also come in the QO line as well.
Panels I don't like are Cuttler Hammer/Eaton BR. These panels are very poorly made, the KO are weak, only have a neutral bus on one side, they have aluminum buses, and the breaker screws are junk!
I also don't like GE panel that use the skinny breakers. The panels are too small (see how much room you have after installing 40 circuits) , the bus connection is very small with the thin breakers, you can only put 2 pole breakers in some locations where they hit both buses, and the thin breakers are getting pointless with AFCI requirements. I do like GE full size breakers/panels and they are the few AFCI breakers that can share a neutral of a multiwire circuit because they do not rely on ground fault CT's
For new construction/rewiring where there's going to be a lot of AFCI's I like Square D's QO series with the plug-on neutrals. I also like how they have a proprietary design where you can't mis-match breakers.
For service changes and commercial I generally use Siemens PL series with a copper buss. It's good quality and reasonably priced.
I stay away from anything with an aluminum buss.
Eaton equipment isn't really available around here so I don't have much experience other than ripping it out. The nice thing is the BR breakers are listed for just about anything.
I refuse to install GE. I've replaced more failed GE than everything else combined. Plus the breakers don't always like to trip.
I generally go with Siemens PL as they are widely available in my area at a reasonable price with a number of high-end features. Of course Q0 and CH are both great panels, but will cost you more for the privilege; I happily work with these if the client is OK with the cost. I do not install BR or General Electric panels. I have done some HOM panels, but don't really care for them compared to Siemens at roughly the same price.
