water heater electrical
Old 01-03-17, 08:20 AM
D
hi all,
i need a new water heater and the current one is up on the wall and is a short version, plumber wants to install a tall version since they are easier to work on and the wall cabinet the short is in makes it impossible to get to.
he wants to splice the electrical wiring into a box and then into the new heater the circuits are a dual 30a and he stated, he thinks its #10 wire.
the exisiting and new units are 4500/4500 240v
is this acceptable to do? can i verify the wire size that is on the existing unit somehow?
Old 01-03-17, 08:48 AM
Justin Smith's Avatar
Received 1 Upvote on 1 Post
#10 on a 2-pole 25 or 30 is fine.
Old 01-03-17, 08:52 AM
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
Why is the plumber doing the electrical?
Old 01-03-17, 09:03 AM
D
thank you. he bought 10/2 from home depot its an orange plastic cover on the wire
Old 01-03-17, 09:10 AM
ray2047's Avatar
That is the correct wire. Making connections in a box is the correct way.
