When do light fixtures use lampcord vs THHN/THWN?
Old 01-08-17, 01:47 PM
K
Question When do light fixtures use lampcord vs THHN/THWN?
Old 01-08-17, 02:01 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Lamps almost always use lampcord as opposed to THHN due to the size requirements of the channels in the lamps (for instance chandeliers) It is cheaper, too.
Old 01-08-17, 06:04 PM
Marq1's Avatar
Received 1,137 Upvotes on 1,031 Posts
THHN/THWN wire is internal to walls, box to box.
Lamp cord goes from the box/plug to the lamp.
Old 01-08-17, 08:30 PM
K
I've seen some light fixtures with clearly labelled THHN leads.
Hence the confusion.
Old 01-09-17, 04:04 AM
chandler's Avatar
Only sheathed cables will be internal to walls. THHN will be in conduit.
It isn't out of the realm of possibility for THHN to be used in lamps. Like I said, there is a cheaper method, and most manufacturers will choose lampcord. Neither is wrong.
Old 01-09-17, 04:40 AM
E
Received 3 Upvotes on 3 Posts
Most Lamp cord is SPT-1 or SPT-2
This message is too short so I added this line
Old 01-09-17, 08:31 AM
I
Received 45 Upvotes on 43 Posts
It's also worth noting that lighting fixtures are sort of the wild west when it comes to following codes and regulations. If you buy a name brand fixture from a good dealer it will be UL listed and use all rated internal components, including wire. However, light fixtures from antique/craft shops or random internet dealers there's a good chance you'll get either a homemade or imported fixture that is not UL listed, and who knows what kind of materials they used. Additionally they may use one prefab UL listed component, like a cord or bulb holder, then from that try to imply that the entire fixture is UL listed.
