3way switch for 800W light fixture
Old 01-25-17, 11:43 AM
E
Hi,
Was looking for help in getting wires connected properly ... Dimmer is rated for 1000W.
Diagram hopefully explains the wires coming into box....
Thanks Erik
Old 01-25-17, 12:56 PM
ray2047's Avatar
The diagram is not for a 3-way switch. A 3-way switch circuit has two switches at different locations. What you seem to have is a dimmer that can be used either for a single switch in one location or on a 3-way circuit. On a single switch use either the red or blue lead is capped but not used. Does the instructions say which lead is not used? Does the dimmer also have a white lead?
If you really do mean a three way show the other switch and give us make and model of the dimmer and if it uses a slave.
Old 01-25-17, 04:20 PM
E
Dimmer switch
Hi Ray,
You're correct, I have a Leviton 4542 10 dimmer switch that I just want to use for the ceiling light. It's rated for 1000w
It has the black, white, red, yellow (flagged for use in 3-way) and the green ground.
Would you be able to give me a blow by blow on where wires are connected?
Thanks
Erik
Old 01-25-17, 04:24 PM
Received 3,877 Upvotes on 3,475 Posts
Is that a two gang box ?
Will you still be using a switch to control the receptacles ?
Please confirm and post the full model number. I'm getting a Vizia Z wave control.
Old 01-25-17, 05:27 PM
ray2047's Avatar
Here is one possible way to wire it assuming you want the receptacle half switched but wait until you have given PJ the info he requested and he has confirmed my diagram. He's the pro not me.
Larger image: http://myphotos.mypclinuxos.com/images/ray2047/g2.jpg
Old 01-25-17, 05:33 PM
Your diagram is good Ray but most standard dimmers don't need neutral.
Interesting.... your assuming that red is always live to receptacles while I would assume black was always live.
Although in this instance it wouldn't make any difference unless there were always live receptacles online after the switched ones.
Old 01-25-17, 06:10 PM
ray2047's Avatar
Pete, I wouldn't expect white on a dimmer but his diagram shows white. I was guessing it was for the electronics or maybe I misread his diagram.
Yes I screwed that one up. Thanks for catching that. Now corrected.
Old 01-25-17, 06:25 PM
E
Hi guys,
Yes, it's a two gang box.
And the switch was for the receptacles.
Perhaps the model # is DZMX1 , leviton
The other numbers on back of packaging are very long ....
Old 01-25-17, 07:35 PM
pcboss's Avatar
Received 192 Upvotes on 168 Posts
A dimmer switch cannot be used on a standard receptacle.
Old 01-25-17, 07:56 PM
ray2047's Avatar
It is my understanding the dimmer is for the light. The receptacle is on a SPST switch.
Old 01-25-17, 08:07 PM
E
That's correct Ray. Dimmer is for the light... Going to wire things up tomorrow !
Old 01-25-17, 08:08 PM
pcboss's Avatar
Just wanted to clarify. Thanks
Old 01-25-17, 09:00 PM
ray2047's Avatar
And to clarify you do only want to switch half the switch only. That question got lost.
Old 01-26-17, 08:42 AM
E
Well, I'm just putting things back the way I found them.... Except with the inclusion of this new dimmer switch for the new ceiling light. Which has 20 bulbs in it and is like staring at the sun when it is on full.... Thus the need for the dimmer. ; )
Old 01-26-17, 01:31 PM
E
Complete!
Hey guys,
Successful install!
Thanks to everyone for the sharing of the knowledge.!
Much appreciated. 10 karma points to all concerned! : )
Old 01-26-17, 02:36 PM
ray2047's Avatar
Great! Thanks for letting us know it worked for you. Always glad to help.
