table saw kicks reset
Old 03-30-17, 05:15 PM
F
I purchased a craftsman table saw 10" with 2 non working motors, one has a locked up bearing on the end the other seemed fine, I can turn it with my hand I put it in the table and it runs for 5-6 seconds and kicks the reset switch. wondering if i need to find a new motor or a reset switch?
Old 03-30-17, 05:17 PM
Received 1,113 Votes on 1,033 Posts
Probably not the reset switch bad.
More likely a defective start capacitor, run capacitor and even more likely is a stuck centrifugal start switch. That switch can be found in the end cap of the motor.... if that motor uses it.
Old 03-30-17, 05:28 PM
F
yes used motor, one of the brushes was broke off, i did replace that. when you say end cap, you mean the end where brushes are?
