Octagon box - set back
Received 0 Votes
I am installing boxes for 2 new sconces in a bathroom I'm remodeling. Normally I use a square box with a mud ring and the box is behind the drywall and the ring is the depth of the drywall. I found 2 octagonal boxes (new work) in the garage. They have a 5/8 set back when mounted to the front of the stud (I have 5/8" drywall). I am guessing that is because you don't use a mud ring with these. I just want to make sure I can use these without a problem.
Weight isn't an issue as the sconces are only a few pounds.
Those are fine for that application.
Once covered with sheetrock they are plenty strong for wall sconces.
Did I misunderstand ?
I took it that the box mounted projects 5/8" and will be even with the rock.
