Improvised Grounding Rod
Old 06-11-17, 03:37 PM
No doubt "improvised" is making some of you cringe, but I was thinking about retasking some aluminum SER cable and was wondering if I could use lengths of the individual wires to use as grounding rods. Eh?
Old 06-11-17, 05:24 PM
What will you be grounding?
Old 06-11-17, 06:26 PM
Received 1 Upvote on 1 Post
Are you asking whether it will work? To which the answer is maybe. Or are you asking if it would be code compliant? To which the answer is NO!
Old 06-11-17, 06:45 PM
I'd be grounding the breaker box in my cabin. So would it be a corrosion issue? Not trying to beat the system, just searching for knowledge.
Old 06-11-17, 08:01 PM
ray2047's Avatar
Aluminum can't be used touching ground, 250.64(A). Only an approved ground rod can be used. Yes, corrosion is one consideration. Why don't you want to use a ground rod. If you can't drive it straight you can drive it at 45 or bury it in a trench.
Old 06-12-17, 05:29 AM
T
Received 74 Upvotes on 69 Posts
Aluminum oxides rapidly, making its surface conductivity nil. Its a bad material for a ground rod.
Old 06-12-17, 06:08 AM
Not that I don't want to use grounding rods, just trying to stifle the flow of my rapidly diminishing cash. Thanks guys.
Old 06-12-17, 10:26 AM
I
Received 45 Upvotes on 43 Posts
There are some other approved earth ground solutions, but anything aluminum is not one of them. The corrosion factor makes it virtually useless in moist soil.
