gcfi outside outlets
how do i wire in 2 gcfi outlets in a double box when i have two wires i.e. 2 black and two white wires with 2 grounds?
- Return the second GFCI recptacle and get a non GFCI receptacle.
- Connect power in to the LINE side of the GFCI receptacle.
- Connect the LOAD side of the GFCI receptacle to the non GFCI receptacle.
- Black to brass, white to silver, bare to green.
Be sure to use outdoor rated receptacles and an in use bubble cover.
