16 gauge to 6 gauge wire splice?
Received 0 Votes
Hi,
I am new to the forums and completely new to electrical work.
I was working on replacing an inline fuse for an electric mini bike.
However I only have a 6 gauge in line fuse.
The current wires leading from the bike's controller and battery are 16 gauge. Can I splice the two 16 gauge (thin wires) to the 6 gauge (thick wire) inline fuse?
Or would this lead to issues, I was thinking one possible issue would be that the thick inline fuse wire would offer too much resistance to the 16 gauge wire and the fuse wouldn't blow when it should?
Sorry if this is a stupid question and thank you for your help!
-John
-John
Then you need a fuseholder and a 30A fuse unless the controller specifies a larger size.
Although the #6 is a tad large for the application it will work fine with the proper fuse in it.
The only concern I have is #16 wiring is usually only used for circuits up to 15A or so in a DC application like you have.
