Smart Switch install- tie into neutral bundle
I want to install a Honeywell Smart switch to the replace the switch on the right. It requires tapping into the neutrals and wanted to reaffirm that the bundle of 3 or 4 wires with arrow is the neutral. With adding another neutral, what cap would best be used? Also would I need to straighten all wires out or can I wrap the new wire around the outside with the new nut.
