Can I use Multi-Cable Staples to run wire horizontally?
Old 07-26-17, 08:43 AM
B
Can I use Multi-Cable Staples to run wire from post to post?
I am running 5 or 6 runs of wire in my attic and thought I would use the Multi-Cable Staples to give myself more room.
Here's a picture of what it looks like:
They definitely seem strong enough to handle the weight, but I've never seen them used in this manner and am not sure it's up to code.
I also do see anything on their website or the packaging that says anything about this:SnapSHOT Multi-Cable Staple, Red, NM (flat and round), Coaxial and Data/CAT V, (100/pk) | Gardner Bender
Old 07-26-17, 04:06 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
As long as the spacing requirements are met and the cable is not subject to damage you should be good.
