Dehumidifier says not to use extension cord
Old 08-13-17, 06:56 PM
T
I just put a new dehumidifier in my basement. The directions say not to use an extension cord. There is no outlet near where I want to put it. Would it be ok to use one if it is heavy enough? And if so how big should it be? Thanks
Old 08-13-17, 07:02 PM
Tolyn Ironhand's Avatar
Received 223 Votes on 196 Posts
Cords can be dangerous for many reasons, which is why manufacturers don't want people to use them. However, they are fine for temporary use. I would recommend to match the cord gauge to the rating of the circuit. Use a #14/3 cord for a 15 amp circuit and #12/3 for a 20 amp circuit. Also, if the basement is unfinished, make sure you plug it into a GFCI protected receptacle/circuit.
Old 08-13-17, 07:14 PM
the_tow_guy's Avatar
Received 60 Votes on 49 Posts
Or consider adding a gfci protected outlet where you'll be using it if it will be long term.
Old 08-14-17, 03:47 AM
Marq1's Avatar
Received 395 Votes on 369 Posts
You are being protected by the stupidity of the masses.
Dehumidifier pulls amps, not suitable for those $0.99 extension cords that everybody uses.
Old 08-14-17, 04:41 AM
Norm201's Avatar
Received 255 Votes on 229 Posts
Suspend the cord overhead, don't let it lay on the floor.
Old 08-14-17, 05:09 AM
T
Thanks guys, i will put in a gfci.
Old 08-14-17, 08:35 AM
Received 94 Votes on 83 Posts
Good choice. By definition, temporary use of an extension cord is 90 or fewer days. I certainly need to run my longer than that each year.
