adding power to barn
Old 09-20-17, 12:17 PM
I want to add power to my barn which is 150' from my main power providing 110 and 220. I have read that I need 2 hots, a neutral, and a ground. Is this correct? Why can I not run 2 hots and the neutral and just ground the sub panel with a grounding rod?
Old 09-20-17, 02:01 PM
P
Received 114 Votes on 90 Posts
National Code doesn't allow it. You need to have an equipment ground running between panels. Ground rods are for lighting strikes, equipment ground is for clearing fault current such as shorts.
Old 09-20-17, 02:25 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Nominal voltages are 120v and 240v.
