Does EMT conduit need to be grounded?
Old 10-18-17, 06:28 AM
A
I am running surface mounted emt conduit and metal boxes in my basement. Can I just ground the box and receptacle normally or does the conduit itself have to be grounded somehow? Is there a situation where a conductor gets lose/cut in the conduit and the conduit itself could become hot? Or would the conduit just take the ground from the box's grounding screw?
It's all 12/2 romex.
Old 10-18-17, 06:44 AM
ray2047's Avatar
The EMT should start at a grounded metal box or panel. Each subsequent box should be metal with device grounds pigtailed to the metal box.
Old 10-18-17, 02:05 PM
pcboss's Avatar
Received 204 Upvotes on 178 Posts
A loose connection could cause the lost of grounding and leave the conduit hot. This is why secure connections are so important . A redundant grounding means avoids leaving a conduit hot if a connection came loose.
Old 10-19-17, 10:24 AM
I
Received 45 Upvotes on 43 Posts
The conduit itself is grounded through the metal junction boxes and correct box fittings tightly installed to the conduit. You cannot use EMT conduit with plastic boxes for this reason.
