Direct wiring security camera power
Old 10-20-17, 12:03 PM
Received 4 Upvotes on 4 Posts
Hi.
I have a security camera that someone wired by punching a hole in the wall and plugging in into an outlet. I want to get this cleaned up and direct wire it.
Can anyone provide me with directions on how to splice the power cable and what wires to hook them up to inside the outlet?
Thanks, sl
Old 10-20-17, 01:16 PM
I
Received 45 Upvotes on 43 Posts
Look at the low voltage wiring and see if it is class 2 rated. If so, it is allowed to go through the wall space. If not, see if you can replace the in-wall wiring with equivalent or larger size wire that does have a class 2 rating.
The Cat5 cable is probably OK, but I can't tell about the other 2 conductor cable.
Old 10-20-17, 04:12 PM
Received 3,593 Upvotes on 3,222 Posts
You cannot eliminate that box. That is a powerline ethernet extender. That carries the data from your camera to your router thru the house electric wiring. It looks to have a custom connection to power the camera also.
Old 10-21-17, 05:52 PM
thanks, you are correct about that. I have a new camera now that is wireless. I will take a new picture of the new cord soon and start over here. thanks.
Old 10-21-17, 11:51 PM
Continue on with this thread.
Just FYI..... cameras run on low voltage power..... usually using a plug in wall wart..... and cannot be wired directly into an electrical box.
Old 10-23-17, 12:40 PM
Update camera with picture
Hi.
I uploaded a picture of the new cord and adapter. Would be great if I can direct wire it.
Thanks, everyone.
Old 10-23-17, 02:16 PM
pcboss's Avatar
Received 175 Upvotes on 153 Posts
You would need to install another receptacle on the other side of the wall. That cable is not for in-wall usage.
Old 10-23-17, 08:27 PM
Even if it were proper to run that wire thru the wall...... your problem is that plug in unit is a power supply that drops the AC voltage to something like 12v for the camera. It must be used.
Old 10-24-17, 07:15 AM
I
For a hardwired network camera, I'd recommend a PoE (power over Ethernet) version. You only need to run a cat5/5e/6 cable to the camera location from your router/network switch. You can use a cheap power injector on the cable which will send power along with the data on the single Ethernet cable.
Old 10-24-17, 08:48 AM
Wow. I have never heard of PoE before. That's cool. I have all these wireless cameras now so I think I might as well just install an outlet in that closest where the wire is run through to the wall outlet.
Thanks eveyrone
