Screwed into cable by mistake
Old 11-03-17, 11:50 AM
Q
Received 1 Upvote on 1 Post
Screwed into this electric cable by mistake as it was close to drywall.
I can see a copper wire inside - assume it's the ground but not sure.
Can I just tape it with electrical tape?
Old 11-03-17, 04:31 PM
Received 126 Upvotes on 111 Posts
Hard to see what you have done or where it is even after enlarging it.
Old 11-03-17, 06:11 PM
Q
I cut the sheath off to have a look. The black had some exposed copper so I pulled the 3 wires apart, put electrical tape around the live, then tape over all three again.
is that ok?
Old 11-03-17, 09:18 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
Sure ....IMO its ok..
Old 11-04-17, 07:31 AM
L
Received 195 Upvotes on 167 Posts
Make sure there are enough copper left on the wires. When the live wires are shorted, usually some copper melts away. This makes the wire thinner at that point, thus higher electrical resistance. This can lead to over heating at the point.
I will not worry if most of the copper is intact, but if it has melted 1/3 or more of the wire, I'd cut and splice new section.
Old 11-06-17, 06:49 AM
Q
Didn't look like the copper was damaged, just the black cover.
If splicing, you need a junction box installed there?
