Best way to to make low voltage landscape cable junctions?
There seems to be multiple ways to do it.
The best way is to solder them and then cover with heat shrink. A slow and time consuming process.
The easiest and most effective way is to use the gel filled wire nuts.
Always point the open end of the wirenut down so it can't fill with water.
