Can I Install This in my '70's Home?
Old 12-05-17, 09:24 AM
A
This is an older sauna heater.
Do you forsee any issues with having this unit installed in my 1971 HUD home? I intend to employ professional electrician but is there some obvious reason why this will not work? The photo is not the best but here is the info:
240V
6kW
25 amps
Thank you.
Old 12-05-17, 09:36 AM
Received 4,094 Upvotes on 3,677 Posts
Welcome to the forums.
You should explain what the unit is so we don't have to guess.
Looks like a sauna heater.
It requires a 240v 30A circuit.
If you have the space for a two pole breaker you should be fine.
Old 12-05-17, 09:49 AM
A
You are correct, it is a sauna heater. I edited the intro to specify the type of unit. Thank you for your input !
Old 12-05-17, 09:57 AM
Good job. Any further questions ?
Old 12-05-17, 10:03 AM
A
No, thanks. 25 character minimum.
Old 12-05-17, 06:01 PM
CasualJoe's Avatar
Received 188 Upvotes on 168 Posts
25? Ok ................................
