rewire bathroom gfs plugs
Old 12-08-17, 12:47 PM
W
Have two bathrooms that have gfs plugs that are wired to power on when lights are turned on. Is it possible to wire so they are always on with probable existing wiring?
Old 12-08-17, 04:45 PM
ray2047's Avatar
Open lights and switch boxes and tell us all the wires and connections in them
Old 12-08-17, 04:46 PM
Tolyn Ironhand's Avatar
Received 917 Upvotes on 775 Posts
Maybe. It will depend on how it is wired now. You will need to open up each box and tell us (or pictures are better) what you have for wiring.
Old 12-10-17, 09:10 AM
W
only two wires
just two wires to plug white and blackName:  elec plug 1 013.jpg
Old 12-10-17, 09:34 AM
CasualJoe's Avatar
Received 192 Upvotes on 172 Posts
All I see is a 15 amp GFCI receptacle, where is the plug?
Old 12-10-17, 02:21 PM
You will need to locate where the wires for the GFCI are located. Since it is switched it will be likely coming from the switch box or the light fixture. If it is in the switch box, making it hot all the time should be fairly easy. If it is in the light fixture box, not so much.
Old 12-11-17, 11:29 AM
W
thanks wires come from the junction box for the lights wall switch works both the lights and the GFCI
Old 12-11-17, 03:16 PM
ray2047's Avatar
Then that's what we need to see.
