Converting light switch to receptacle
Received 0 Votes
Brand new to this forum. I have a basic (I hope) question. Doing some kitchen remodeling very soon. We presently have an under the cabinet light with wall switch. We are doing away with this cabinet and do not need the light. We will be adding a microwave to a floor to ceiling cabinet on this wall. I want to convert the present light switch to a receptacle for the microwave. Is it as simple as replacing the light switch with a new receptacle or more complicated? What steps do I need to follow to convert to a receptacle?
It's a little m ore complicated than that. The problem is you won't have neutral at the switch. The neutral will be at the light. You will need to connect one of the wires from the switch to the neutral; at the light.
Normally in an application like that..... power is sent to the switch and then to the light. That means there is hot and neutral at the switch location. At one time an undercounter light would just be connected to any nearby circuit.
That means that light is probably on with some or all of the counter receptacles. That light won't be on its own circuit. If you just want to power a countertop mictrowave..... you may be ok. If you want to power an undercabinet microwave and exhaust combo..... then you need a dedicated 20A circuit. It cannot be connect to the countertop receptacles.
You should start by checking what circuit that light is on and determine everything else that's on the same circuit. Let us know. You may find that to be a busy circuit depending on the age of the wiring,
Received 0 Votes
This is getting a little more complicated. Right now this cabinet light is on the same circuit as my over-the-stove microwave with exhaust hood, and two wall outlets in the nearby den. However, I will be doing away with the over-the-stove microwave during the remodel. The present microwave has its own receptacle which will also be eliminated and is in a different location to where I need the new one. It is on a 20 amp breaker. In effect, when the present microwave is eliminated only the den outlets will be on the circuit. I hope this all makes sense.
Received 0 Votes
Let me take one more stab at this. I just took the cover off the switch. Black wire coming into switch is connected to bottom screw on switch. Black wire from light is connected to top screw on switch. BOTH white wires are connected to each other. Both bare wires are connected to ground screw on switch. So, if I remove the switch from the wall and disconnect the wires from the light switch, I will then be left with one black wire, one white wire, and one ground wire. Can I then connect these 3 remaining wires to a new receptacle and get power to it?
Yes.... and to add one further thing.... it should be GFI receptacle.
At one time it was only if near a sink. Now it's all countertop receptacles.
