Terminal block from generator switched neutral kit
I am going to install a Generac switched neutral kit for my Generac transfer switch. It seems pretty straightforward but I can’t figure out what to do with the insulated terminal block they give you to run the neutrals through. There doesn’t seem to be a way to affix it to the inside of the breaker panel as shown in the instructions. Am I meant to just let it hang by the neutral wires? That seems awfully sloppy.
Thanks for ideas. I am sure some of you have installed these before.
