wiring problem/40amp to 20amp
Old 12-18-17, 09:19 PM
R
Question wiring problem/40amp to 20amp
I have 3 40amp breakers that were installed for tankless water heater. New wiring was routed leaving the 3 40's unused. My shop/garage in in need of additional outlets. Can I convert 40amp to 20amp. Wiring is black & red with white ground?
Old 12-18-17, 10:39 PM
Received 1,318 Votes on 1,218 Posts
Welcome to the forums.
You want to convert the old wiring to run on a 20A breaker.
That cable is black, red and white..... no bare ground ?
Old 12-19-17, 07:11 AM
P
Received 124 Votes on 98 Posts
White should be a neutral. Are the circuits run in metal conduit where perhaps the conduit served as the ground?
Old 12-25-17, 03:39 AM
R
[gave bad info.. there is a bare ground, the white wire is capped off. need to have standard 120 power to the outlet. need 20a because a 15a keeps throwing the breaker if two or more items and lights are on
Old 12-25-17, 03:46 AM
pcboss's Avatar
Received 103 Votes on 89 Posts
The white will need to connect to the receptacle. Check to make sure it is connected in the panel. You will also need the ground.
Old 12-25-17, 08:42 AM
P
I'm going to guess the 40A circuit used #8 copper and you are looking to use the existing wire to serve the 20A outlet(s). You may find that #8 is the max size to fit in a 20A breaker or may be too large. So it may be necessary to splice on some #12 to wire to hook up the breaker and will definitely require some #12 to hook up the 20A 120V outlet(s).
Old 12-28-17, 11:43 AM
R
my original post was wrong. after carefully checking electrical panel there is a bare ground wire , the white wire is capped off
Old 12-28-17, 07:00 PM
Tolyn Ironhand's Avatar
Received 252 Votes on 220 Posts
Is this an attached garage?
Old 12-29-17, 08:59 AM
R
no, garage/workshop is in the basement of my log home. the wiring is black, red with bare ground and a white wire capped off
Old 12-29-17, 03:27 PM
core's Avatar
If there's #8 already nicely run downstairs with a ground, I'd be tempted to throw a small (cheap) subpanel in the basement/shop. Seems like a waste to do it the way you're planning, only getting 1 20A circuit out of the deal. You never know what kind of power-hungry stuff you'll want to use in your workshop later on.
