Swapping 2 Pole Circuit Breaker for 2 1-Pole Circuit Breakers
I am putting in a 240V 2-pole 30A circuit breaker into my electric panel for backfeeding from my Solar inverter, and was hoping to put this on the bottom of the electric panel. But the teeth that the circuit breakers plug into are different shapes, and the 2-pole circuit breaker won't fit as the metal interferes into the part of the circuit breaker that connects to the various branches of the 120V down the center of the panel. Is there certain slots for 1-pole and certain spots for 2-poles on an electrical panel?
Could you let us know the make and model of the panel and approximate age? Some panels do only allow certain types of breakers in certain slots. An overall picture of the inside of the panel would be helpful.
Hopefully this pics will help. But maybe I am worried about details that I don't need to worry about. Do I need to have my backfeeding CB at the bottom of my panel? As you can see in the below pic, it is the 3rd CB on the right.
Here is a picture of the label on the inside of the panel:
Here is a zoom of where I am currently plugging the 2-pole 240V 30A backfeeding CB:
And where I would like to plug it into:
Thanks again for any help!
Your pictures didn't work. They were not image files (JPG, PNG, etc.) but you inserted them as images. How to insert pictures.
I do believe you should be able to use 2 single pole breakers next to each other. However you will have to use a tie bar to connect both levers together. Some breakers allow tie bars some don't so check with the manufacturer of your panel to find out if it allowable.
skeeter
skeeter
Trying to Resend the Pics
Hopefully this pics will help. But maybe I am worried about details that I don't need to worry about. Do I need to have my backfeeding CB at the bottom of my panel? As you can see in the full panel pic, it is the 3rd CB on the right (gap above it).
The other two pics of the panel show the two different interfaces that are available for 1 pole and 2 pole CBs on my panel.
Let me know if this doesn't work or you need more info. My house was built in 2001, so hopefully nothing that is too obsolete.
Received 273 Upvotes
You currently have the 30A DP breaker in spaces 18/20 which is fine. You can put it across any 2 spaces in the empty area that you like. The diagram shows a dotted line through spaces 21 and 22 down to the bottom which means those spaces can take tandem breakers.
All cables entering the panel need clamps and open unused knockout holes need to be plugged.
So you have 10 tandem breakers and from the panel schematic they can only be used in the bottom spaces You could replace two of those tandems with four full size breakers and place them in the middle open spots to free up bottom spaces.
What size breaker is feeding that panel? If less than 200 then you can put the PV breaker anywhere.
Pattenp wrote: All cables entering the panel need clamps and open unused knockout holes need to be plugged.
That is something I didn't know, and looks like whomever did electrical work in the box before me didn't either. Since I don't have great access below my panel (unless I cut out the sheetrock), is there a way to cover up the empty knockouts and to put the clamps on from inside the box?
To clarify cables/wires entering through conduit do not need clamps at the panel entry. For NM cable you can use the 2 piece type clamps and they can be taken apart and inserted from inside the panel with the clamp screws on the inside of the panel. There are snap in plugs that will close open unused knockouts and can be pushed in from the inside of the panel.
