Room extension
Old 02-16-18, 09:27 AM
R
Room extension
I am building a guest room detached from my house with its own power supply to it. I will be running 110 & 220 to this room for lighting and ac/heat (220v window unit) I am installing a 200 amp service box on my pole and a 200 amp 8 spot break box in the room it will be approximately a 40’ run my question is what wire do I need to get to bury and provide the power to the guest room?
Old 02-16-18, 11:09 AM
I
Received 45 Upvotes on 43 Posts
Will this room be a stand-alone apartment such as having it's own kitchen, sleeping, laundry facilities? How big is the building?
Old 02-16-18, 12:39 PM
pcboss's Avatar
Received 177 Upvotes on 155 Posts
A guest room can be served by way less than 200/amps.
I doubt your utility will allow a second service to the property.
Old 02-21-18, 06:13 AM
R
The cabin is 12’x32’ and will have its own plumbing, tankless water heater, and 2-220v window unit ac/heater units along with 2 ceilings fans and normal amenities (cable,tv, microwave, fridge)
Old 02-21-18, 06:17 AM
R
I live in the country so I’m just planning on installing a load center off my utility box and the cabin will have its own sub panel inside
