Installing exterior light
Can someone point me in the right direction for installing a new exterior light (flood light in this case). I m not sure the best practices when it comes to cutting the siding, installing a new box (octagon or square?), insulation, securing it properly, and using plastic covers around it.
I did replace 2 flood lights on existing installs, but now I need to install a brand new one. There is a receptacle inside my house right where I want to install this.
Its plastic siding that snaps on to each other. The location of the light will be adjacent to a receptacle inside the house, so no fishing necessary. i just need to know what to use to cover the hole (also how do I cut it?) properly so water doesnt get in.
These are what I would use for vinyl siding: Arlington | Siding Mounting Blocks You cut the siding out in a square keeping the wood sheathing, fish your wire in the new location, then caulk around the block. The block covers the seam between the block and the siding for a clean look.
The question is, do you place the light fixture box (I'm guessing I use the octagon boxes, not the switch or receptacle ones) behind the wood siding or do you mount it ON the wood siding but behind the vinyl siding? In other words, do you just cut the vinyl siding to shape or do you cut the wood and the vinyl siding together?
Please bear in mind this is a floodlight (in fact it is the ring floodlight).
Now there is a tough one
Oh I see, so literally that entire plastic thing is screwed on to the existing siding
For brick you could use one of these: Arlington | Round Flat Surface Out or use a pancake box and recess it into the brick using a hammer drill or grinder with a diamond blade or cup wheel.
The block posted by Ray sits over the siding. Other styles attach to the sheathing and the siding butts up to them
A masonry device box can fit in the space of about a half brick and is easier to cut in than a round pancake box.
Cutting the masonary blocks is going to be very difficult. Could I not mount a box on top of the masonary bricks? The light will be under the gutters and probably will be protected by the roof extension. I had to drill through these bricks before to run a small 3/4” pvc conduit for my sprinkler controllers and I spent 3 hours making a hole that big with my hammer drill and masonary bits. I obviously could rent a big commercial drill for this but I m going to be about 15 feet up in the air and I dont know if I can exert that much force on wall when i m on a ldder.
So only 1 screw on the brick and rest is on the joint? Hope it doesnt crumble
