Use 240v Hot as Neutral
Hello,
I've recently removed a wall oven from my kitchen that had a dedicated 240v circuit (two hot wires, and a bare ground, no neutral). I would like to change it to a 120v and put my refrigerator in that spot in the kitchen. As there isn't a neutral currently, I was thinking I could take the red-hot wire and hook it to the neutral bussbar in the service panel and use it as neutral for my new 120v fridge outlet. I would mark the wire on either end with white tape or something to show I'm not using it as hot anymore. The other hot (black) wire attach to a new 20a single pole breaker. Just looking for some guidance if I'm off track or not. Thank you.
Ray2047,
If code allows a white or gray colored insulation for the neutral wire, it appears the color has nothing to do with the wire's electrical characteristics. Why can't a white or gray wire (same electrical characteristics as the black /red wire) be pigtailed to the end of the black or red wire to make the neutral connections?
Received 243 Upvotes
If it's a multiconductor cable the conductor color must be continuous for the entire length. There is an exception for marking the ends when maintenance and supervision is ensured by a qualified person NEC 200.6(E) Exception #1
