Office frig says no extension cord. Why?
I have a small office refrigerator. The tag attached to the plug says do not use an extension cord. That seems odd to me. Maybe what they REALLY mean is use an extension cord that is rated to handle the power that the frig will draw. It says it draws 0.8 amps.
Lawyers are probably involved in that warning. How far are you from the nearest receptacle? If installed to code it should be no more than six feet to the nearest receptacle.
Extension cords are only to be used for temporary and are not to replace permanent wiring. If you need a receptacle closer you should add one.
On extension cords: Many people will buy the cheapest extension cords they can find not knowing that they only contain 16 ga wires. depending the length of the cord it can cause voltage drop issues depending on the load.
I need to run an extension cord 20 feet to this office refrigerator. Otherwise I could set this refrigerator up in the bedroom but my Air BnB guests might not be able to sleep with this thing running. I guess they could shut it off if it bothers them and they're not using it.
Is a LONGER extension cord more likely to heat up and fail?
BTW I'm looking at the cord that's part of this refrigerator. How is IT not a hazard if cords are hazardous?
I need to run an extension cord 20 feet from this office refrigerator as part of an Air BnB rental space.
Longer extension cords with a thin wires can cause a voltage drop and cause your refrigerator to fail. If you use really cheap and thin extension cords, then it may also over heat.
If you use a quality 14AWG or 12AWG extension cord, it is very unlikely you will have any safety hazard or failures, but it still is illegal due to the fact they are made for temporary uses only.
Geez! It's only one of those little office refrigerators. Just use a heavy duty extension cord not much longer than you need. Run it where no one will trip on it (to protect the food). As far as the "6 foot code" there are many buildings/houses the predate the requirement.
Like Pat says "Geez!". Just good a good quality cord that is at least 14 gauge and if you want overkill get 12 gauge and be done with it. Most important thing is keep the cord out of the way so it doesn't get stepped on or pinched.
skeeter
skeeter
but "why does the tag say no ext. cord?"; because they don't want to see the unit come back for a warranty claim with a seized compressor if some loser used a 50' 18awg cord.
Other than a possible physical damages, no.
Well I'm "temporarily" renting a room and bath for the summer. I think I'll look to move the frig to a closet that's closer to an outlet. It will be louder. Maybe that will save me some $$ because guests will likely turn off the frig so they can sleep better.
BTW what about microwave ovens? Do they have this same problem with extension cords?
Originally Posted by AndyRooney
". . . Office frig says no extension cord. Why? . . .
A properly sized extension cord is electrically no different than the wire leading to a new receptacle. The problem is consumers using undersized wire for the amperage demand and hazards with loose wire, in a kitchen, i.e. The amperage for microwaves is typically much higher than an office refrigerator.
Extension cords and portable outlet strips add risk to an install in a few ways. there is another ground connection that adds shock risk. Take a 6 outlet strip. If the first ground connection is lost, it affects everything downstream plugged into the strip. If you had a 6 way strip feeding another 6 way strip, the problem compounds.
There is an "uncontrolled" connection point that adds shock risk, since a wall outlet is now not the connection point, but is very likely to be on the floor, where it is subject to water spills, abrasion, metal furniture legs, etc.
At some point, the UL and NEC's say, enough is enough. We determine that more than one outlet strip in use is not safe enough, same with "permanent" extension cords.
This goes beyond wire gauge.
But extension cord wire is stranded while house wire is solid - doesn't that make a difference ??
Stranded wires are used in the conduits all the time as well.
I have seen some very cheap extension cords use CCA (Copper Clad Aluminum). It does work, but usually more fragile.
