220v wiring types
220v wiring types
Hi all, I am in the process of building a new cnc control and I need a little more reassurance that I would be wiring correctly. I have an image of how I plan to do the wiring. Would this work on the desktop pc adding a neutral, it says on side of pc that it is 240v3a or 110 6a.
Welcome to the forums.
A very vague question.
We can assume your CNC machine runs on 240vac only.
Are you attempting to use one of those hot wires with a "neutral" to run the control/computer ?
The desktop could be powered off the same 240v but I wouldn't recommend it.
The desktop should be on its own supply circuit....not shared with the machine.
There was a picture of the wiring but it didn't upload. If you read forums on building a cnc machine it's pretty standard to have one power plug and everything on the same circuit. The computer can be used in Europe and has it's own power source made for 240 hence can be used in europe. All I need is a neutral wire so the electricity returns to the transformer on the pole.
Am I thinking correctly? I could connect the one leg of 110v and a neutral to the pc
I feel the same way when people ask about welding lol. I currently have 6-2 wire powering a welding machine ( an outlet). I have to add the neutral wire and a sub panel. 2 breakers inside. 1 goes to the welding plug wired with 2 110v legs and ground, other to cnc 2 110v 1 neutral and a ground. By using just 1 hot leg the neutral and the ground for the pc? Also should I worry about a power supply saying 230v, do I need to add a resistor to step it down 10v?
The 130v usually derives from idiots writing the instructions. They are just repeating what they heard or read somewhere. If it is intended for use in the US and is 60Hz not 50Hz there should be no problem.
I'm not understanding why the neutral is sharing the ground in the diagram.
When I put the meter on one leg and the ground I get 120v
Voltage is always measured between two places e.g. between two wires.
Typically there are three wires coming to the house from the utility pole. I will refer to them first by color which the lines may or may not have. Measuring from red to white gives about 120 volts. Measuring from black to white gives about 120 volts. Measuring from red to black gives about 240 volts, all regardless of what or how many lights and appliances and tools are being used at the same time.
An appliance that uses "240 volts only" will be supplied using just 2 wires, black and red from above. Current that comes in on black will all return on red. A light that uses 120 volts only will be supplied with white and one of the others. Many appliances have some internal components that use 120 volts and some internal components that use 240 volts. All three wires will supply the appliance and some current will flow on each of the lines: red, white, and black.
By convention and by code in the U.S., one of the three lines, the white, is grounded. It is called "the grounded conductor" for this reason and in U.S., inside the house it must actually have white covering. The other two legs and branches from them may be any color including black but not green (or white). Now that we have designated one line as grounded, the other lines (red and black above) are considered to be hot.
Once in the house, the wiring must include a fourth conductor, technically called the grounding conductor, that is bare or with a green covering, and forming a network following the other wiring. The grounding conductor network is connected to the house grounding system which may include ground rods and/or a water pipe. The network of grounded conductors (referred to as white previously) is connected to the grounding system at just one location, in the panel with the first whole house disconnecting switch or breaker. In a sense, the grounding conductor (we can say ground for short) and the grounded conductor (we use the term neutral) are redundant but ground must not be used as a normal current return (substitute for the neutral) inside the house. For 120 volts (in the U.S.) it is not mandatory to bring along both hot legs so many circuits will have three conductors, hot, neutral, and ground.
Some computers have a little switch on the power supply in back to select 120 volts or 240 volts. If plugged into a receptacle supplying the wrong voltage, the computer will be fried. A few computers will automatically adjust to any voltage between about 120 and about 240 without the need to flip a little switch.
You do not need resistors or transformers or other additional or special equipment when plugging things rated for anywhere from 220 to 250 volts into a receptacle where you measured about 240 volts. Same for 110 to 130 volt equipment into a receptacle where you measured about 120 volts.
The method is correct but the nominal voltages available are wrong. Nominal voltage is is 120 volts and 240 volts ± 10%. He is also wrong when he refers to the red and black as 110 [sic]. They are the 240v legs.
Nominal voltages in the US are as follows: 120, 208, 240 , 277, 480. 347 and 600 volts can also be found in some industrial settings.
Common electrical systems are:
Single phase 120/240 volts
Three phase 120/240 volts Delta
Three phase 120/208 volts Wye
Three phase 277/480 volts Wye
Three phase 347/600 volts Wye
Voltage is nominal and will vary +/- 10%
