Ghost voltages
Ghost voltages
Hi All, there are several links out there on Ghost or Phantom voltages when measuring with digital meters.
Here is one. http://support.fluke.com/find-sales/...105317_A_w.pdf
Geo
Geo
Ya,all these years and never really gave much thought as to what was causing them,I guess I just accepted it.
As an electrician...... I rarely, if ever, use a digital voltmeter when checking for circuit voltages in AC wiring. The early voltage testers called wiggys had an electromagnetic coil in them which negated open circuit (ghost voltages). Square-D-WIGGY-VOLTAGE-TESTER
That's why we recommend using analog meters as they are low impedance and are not subjest to induced voltages.
Fluke sells a whole aramada of proper voltage checkers starting from around $30.
I use specifically a Fluke T+ tester which I consider to be the best tester for the money.
Here's an awesome deal at $95. Fluke-t-pro-1ac-kit
