How to connect this timer switch
Old 06-12-18, 04:41 PM
A
The instruction manual talks about 3 wires. The switch I'm replacing only has 2, both of which are black.
Old 06-12-18, 05:23 PM
Received 4,094 Upvotes on 3,677 Posts
Follow the two wires back into the box. They should go into cables with a white wire. There's a good chance that the two white wires from those two black wires are tied together. That would be the neutral connection you need for your timer.
Old 06-12-18, 05:54 PM
A
Yes the black wires are capped off with both black and a white wire. It's a mess of wires. I will have to have an electrician deal with this then. I don't want to have to unscrew these caps to get this connected. Hopefully I can find someone who charges less than $150 in LA.
