Kenny clamp
Old 06-27-18, 01:41 PM
T
Kenny clamp
What is the main purpose of this an is it not required in some areas?
No one local here in the supply houses including techs has even heard of it ,nor do they carry it though its been added to the NEC several years ago..
Im assuming it wont be a issue,not using this "Kenny clamp" when im inspected as
grounding meter box.Someone mentioned the importance of it though
I have a #4 copper coming in to neutral lug ,as ground,on bar from the rod.
Any info is appreciated
Old 06-27-18, 01:45 PM
T
It uses solid or braided
Cant load pic..
Its brass an used at entry of meterbox for ground .
Added to NEC 2010 250.8
Old 06-27-18, 01:54 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Old 06-27-18, 05:47 PM
Tolyn Ironhand's Avatar
Received 211 Votes on 187 Posts
There is no NEC 2010, only 2008 and 2011. I have never seen, used, or heard of a Kenny clamp. It looks like just a bushing for a ground wire to pass through. I normally will just drill a hole or use a plastic bushing in a 1/2" KO
Old 06-27-18, 06:36 PM
pcboss's Avatar
Received 87 Votes on 74 Posts
The Kenny clamp was designed in Maryland by an inspector as I understand it. After getting it listed it became a local code requirement . I believe it has something to due with a NM clamp not being listed for the bare and possibly the choke as a gec passed through the hole in a panel.
Old 06-27-18, 07:52 PM
T
2011.file
Tried to upload it
2011 changes
It didnt go in till 2011 but Aug 7th 2010 was when it was added ...
Cant send link
Old 06-28-18, 08:05 AM
CasualJoe's Avatar
Received 87 Votes on 77 Posts
Sounds like politics in action.
Old 06-28-18, 08:26 AM
Received 1,121 Votes on 1,041 Posts
Definitely politics in action. For 99.9% of the applications... the NM clamp has worked fine.
