Disable 3-way switch
Old 07-06-18, 10:40 PM
R
Received 1 Vote on 1 Post
When my house was built the plan was to have some sort of water feature out back that could be controlled by a pair of 3-way switches inside the house, but this never happened.
I now want to run the roughed in cable to the outside and install a few electrical outlets in the backyard. How do i re-wire the 3-way switches to effectively turn them into "dummy" switches and always have power flowing to the back yard?
Old 07-07-18, 04:47 AM
pcboss's Avatar
Received 113 Votes on 98 Posts
This is going to depend on how the wiring was run. Can you tell us the connections you have at the boxes now? Do you have a multimeter to test for voltage ?
Old 07-07-18, 08:22 AM
R
Yes I do have a multimeter. I'll check the connections and post back, thanks.
Old 07-07-18, 11:20 AM
R
Sorry bad intel, it's not a 3-way switch but there is also no power going to the switch that I can tell. I'm thinking there's a possibility that the builder roughed in the switch but never connected it to the panel? Supposed to be a dedicated circuit for this. There's some NMWU 12 wire that appears to runs from the switch to the outside but I can't really see how that switch would get power. Your thoughts?
Old 07-07-18, 12:56 PM
Received 1,480 Votes on 1,368 Posts
Possibly it goes to the panel but is not connected to a breaker. It'd be pretty hard for us to help you much further. You'd need to determine where that three wire cable goes.
Old 07-07-18, 02:43 PM
R
it does not go to the panel as far as I can tell, i wired up my basement and never came across any cable that wasn't connected to the panel. How can I test this cable to determine if it's only connected to that switch and doesn't terminate anywhere else?
