Running a neutral line
Old 07-15-18, 05:50 PM
G
I went to install a electronic timer switch, and discovered that there is no neutral line (white) to the existing switch.
I was going to run a neutral from a different outlet, but wanted to double check that it is ok, since the existing wires seem to come from a different direction.
I wanna run the neutral from this outlet since it's closer and access is easier.
Thanks!
Old 07-15-18, 06:08 PM
Received 3,951 Upvotes on 3,544 Posts
You cannot run just a neutral wire. The wiring must remain in one jacket.
Why not use a timer that doesn't require a neutral. Do you want a recommendation ?
Old 07-15-18, 10:24 PM
G
It's a vacation property that we own. The switch is for a ice eaves wire, and I'd like to set it on a regular schedule, since we won't be in the house regularly.
There are two switches...for one of them, I think I can run a new romex, the second one may be a bit more challenging, so I'll have to investigate more.
The previous owner was an electrician, so there is a bunch of custom stuff that has me scratching my head
Old 07-15-18, 10:32 PM
ray2047's Avatar
Are you saying there is a receptacle for the eve heaters? If so and power comes in there you need to replace the 2-conductor cable to the switch with a 3-conductor cable.
Old 07-15-18, 11:02 PM
G
Correct, I'm replacing a existing switch (one of those that you turn a rotary dial to the desired time).
I'll see if I can fish a new wire to the existing switch.
Old 07-16-18, 12:18 AM
ray2047's Avatar
You can't fish a wire. It must be a 3-conductor cable.
Old 07-16-18, 05:06 AM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Hi, it seems a bit odd to put gutter heat on a timer, how are you going tell when and if they need to be on?
Just curious.
Geo
Old 07-16-18, 08:31 AM
G
Geo, you're right, it is a bit odd, but I won't be there to know if I need it, and I'd rather be safe than have the gutters all messed up, it'll be on during the cold months so, I'm not terribly worried.
Old 07-16-18, 10:24 AM
Z
Received 422 Upvotes on 375 Posts
Have you considered an automatic water/temperature-sensing switch?
Like this:
https://www.amazon.com/Easy-Heat-RS-.../dp/B000BMABZG
(This one has a lot of poor reviews, but there are probably better ones out there)
Old 07-18-18, 09:43 AM
G
I was able to get this to work for one switch.
For the other switch, it is controlling an outlet outside, and hence doesn't have a "load" wire, just a neutral and a hot, and the switches I bought need all three.
the challenge here is that the run to the outlet is long, and I'm not sure if i can access all of it. What happens if I run a new romex from a close by outlet, just for the neutral line (and cap off the rest). Does the neutral actually need to run to the outlet itself?
Old 07-18-18, 12:27 PM
ray2047's Avatar
All conductors must be in the same raceway or sheath. You need to abandon the 2-conductor cable and replace with a 3-conductor cable or use a device that does not use a neutral.
