lost kitchen power
Old 08-07-18, 01:12 PM
K
lost kitchen power
Hi,I gotta bad wire from kitchen recp to dining room.looking to trace route w/o getting into the walls {concrete].It's old wiring brown stuff maybe 12g no grd. looking for ideas.loc
Old 08-07-18, 02:20 PM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
It.is normal.for the wiring to go from one box to the next closest box. You can also.check the last working or first non working receptacle.
Old 08-07-18, 05:16 PM
Received 125 Upvotes on 110 Posts
100% sure someone did not add a GFI to protect the kitchen outlets like should have been done long ago and it's tripped?
Old 08-09-18, 12:06 PM
K
Thanks for ideas,there are no gfi's-I think water got into the walls after several heavy rains.below a windows.loc
Old 08-09-18, 12:10 PM
Received 3,423 Upvotes on 3,069 Posts
The water will not have damaged the wire. If you feel it's a water related issue then it would have to be corroded connections at a junction box that got wet.
