Electric dryer cable run
Old 10-29-18, 10:36 AM
I need to get power to my electric dryer- There is a 220Volt dryer outlet next to it- it runs up to the attic (where all most of my electrical connections are)- It just ends in the attic since renovations were done. I need to extend it another 75 to the electrical panel in the garage- Can I just join the old cable with a new one in a metal junction box? I have done this before with 110- Is it the same for 220?
Old 10-29-18, 11:25 AM
Received 3,881 Upvotes on 3,478 Posts
Yes.... you can splice/extend the cables in a junction box with a cover.
The existing wiring should be #10 for a 30A dryer receptacle. The cable you add should also be #10.
Old 10-29-18, 08:02 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
The first question to answer before extending the cable is whether or not it is 4 wires or three. A three wire circuit should not be extended.
