need old doorbell to be new wiring junction box
I bought a ring doorbell but I cannot put it where my current doorbell is because it needs a larger space as you can see in the picture. I obviously need to extend the wires but I wanted to get something install temporarily. I had thought I could just keep the old doorbell in place and use that as a junction box for the new doorbell and the old doorbell.
But when I put the cover of the old doorbell back on something did not work. But when I took the cover off the old bell then the electric connection worked. But I was wondering if there's a solution that I could keep the old doorbell totally removed.. Obviously there is a hole behind there with the wires coming out. And theoretically some day I may have to put a standard doorbell back there when I move so that I can take the ring with me. So other than getting the correct length of wire I am lost how to make this look somewhat decent and it definitely has to be able to transform to the original state when I move
i guess u could say i need a tiny junction box in place of the doorbell.
edit: i cannot post a pic now but just imagine a tight space where an old thin doorbell is in next to a masonry wall and i need to make it the junction box
The OP is discussing the actual outdoor button. Not a unit hanging on the wall inside. Very confusing.
Having spliced wires at your front door could look a little tacky. The ring unit is pretty big which is one reason why the nest hello has become so popular.
I would like to see a picture of your front door area.
sadly cannot post pic since no way to delete others to make room
its actually back door. the front door installed easily. i love the view the back door cam has given me with my new spotlight. also learned it reset my 30 day free plan when i installed this one. so i may wait to install my 3rd one
that has the same issue with the permastone coming out so far from the house. but that doorbell is weird. i gotta take off aluminium trim to get to the wiring. just is a button sticking out of the trim
Lucky.... I left a reply to your comment in the other forum about attachments.
I've freed up most of your storage space. You were over 10 megs and are now at 4.x megs.
i covered up the old switch with duct tape temporarily and its under a porch so likely wont get too much moisture. i also have to trim down the wood shim too. i didnt take pic of the big hole under the switch. its one reason i want a 'cover' of sorts. id estimate its about 1/2 inch big. the wires out of the wall have two O rings on
i'm going to install another bell on the permastone soon but theres no surface mount , just a button sticking out of the aluminum. so no way to do anything but have the wiring stickout of the tiny hole.
I had to mount one on brick. I used an oscillating saw with a carbide blade and I notched the mortar. I placed the wire in the notch and cemented back over it.
