3 way (SPDT) Switch to alternate light sources?
Hey guys, quick question...
Instead of using multiple 3-way switches for one run of lights, can you use one 3-way switch to alternate between 2 light sources?
I assumed so but I figured I'd double check...
I want to wire a switch in the garage so it turns a ceiling light on/off, but when it's "OFF" I want power to go to a small motion detector light. I could just run the ceiling light from one "traveler" lug and the motion light from the other "traveler" lug, correct? As long as the neutrals are all connected in the switch box?
Thanks
Brian
Thanks
Brian
Is there any way to do this involving 2 switches? As in, two switches to control one light, but when that light is off, another would be powered? Getting complicated here... lol
Thanks
Brian
Thanks
Brian
You will need extra large boxes, namely 28 cubic inches for 14 gauge wiring with power coming into one box and the light wiring going out of the other box.
Note: In a typical 3 way switch the dark terminal is the common terminal and the lighter colored terminals are for the travelers. For each of the two DPDT switches you need to first identify the two sides each with one dark terminal and two lighter terminals..
Are DPDT switches the same as a standard 4-way from the box store?
I've worked with DPDT switches in guitars but never in a wall switch. Not sure what to look for.
Thanks!
Brian
Thanks!
Brian
Not just DPDT. That won't work. You need DPDT center off.
You can achieve what the op wants by using one side of DPDT switches for ceiling fan light and the other side for motion sensor light. Treating each as 3 way switch.
Center off is necessary only if both ceiling fan and motion sensor light needs to be off.
If no "off" position is needed why wouldn't a 3-way connected to a 4-way work? Power to the common of the 3-way. Two travelers from there to feed the 4-way. Then then other two terminals of the 4-way could go to the light and motion detector light.
Be aware that many motion detectors go into different test modes when being turned off then back on again in under a minute. The ones I've seen will either switch to always on, or a test mode where the motion sensor is on regardless of time of day and turns on the light for only 5 sec at a time.
To reset it back to its normal motion detection, you need to turn it off for over 1 minute, then back on.
I can see that potentially being an issue if you turn on the light to get something, then turn it off. You may be able to get around this by switching the light after the motion detector. Or possibly find a motion detector that doesn't do this.
You could also use a photocell to control power to the motion detector light.
