Plasma cutter
Old 04-06-19, 05:39 AM
C
Smile Plasma cutter
I want this:
https://www.eastwood.com/eastwood-ve...hoCyNkQAvD_BwE
Someone kindly tell me what I need to say to my electrician so he can wire the source for this plasma cutter Want to cut 3/8" ....
Old 04-06-19, 05:51 AM
Received 531 Upvotes on 435 Posts
From the manual. Tell this to your electrician.
Our Versa-Cut Plasma Cutter is supplied with the popular NEMA 50P plug, requiring a NEMA-50R recepticle. If a 220-240 VAC, 30 Amp outlet is used a UL listed 30 Amp plug may be installed by a licensed and qualified electrician
Old 04-06-19, 06:01 AM
Tolyn Ironhand's Avatar
Received 914 Upvotes on 772 Posts
Since the plasma cutter comes with a 50 amp plug I would have him install a 50 amp receptacle (NEMA 6-50R) using wire/cable rated for 50 amps. That way if you can use the same receptacle for a welder. The circuit breaker can also be a 50 amp two pole breaker.
Old 04-06-19, 06:19 AM
W
Received 66 Upvotes on 57 Posts
Scroll down to page 4 for installation requirements
https://www.eastwood.com/images/pdf/12740_versacut.pdf
Old 04-06-19, 08:28 AM
The unit can detect and operate on different voltages. I would install a circuit to match the plug comes on the unit.
Old 04-06-19, 04:31 PM
C
tx
tx tolynd and joed. I will go with 220-240 VAC 30 Amp circuit
Old 04-07-19, 05:54 PM
CasualJoe's Avatar
Received 188 Upvotes on 168 Posts
Strange that this unit will operate on a 20 amp 120 volt circuit, but needs a 30 amp circuit when running off 240 volts. I believe I'd wait on the circuit till I could see the data plate on the unit.
Old 04-07-19, 06:30 PM
From the manual
The Eastwood Versa-Cut Plasma Cutter is voltage sensing; it will automatically operate on 110-120 VAC, 50/60Hz., or 220-240 VAC, 50/60 Hz.
